What's the best cleaner and sealer to apply to old bluestone pavers? Should you do this before or after the grout removal/replacement is done?
Hi @ChrisHall,
Welcome to the Bunnings Workshop community. It is wonderful to have you with us.
Could you share a few photos of the pavers and their existing grout? It would also help to know roughly how wide the grout joints are. With this information, we can offer more specific recommendations.
Generally, I'd recommend completing the grout removal and replacement before sealing your bluestone pavers, although you could give the area an initial clean beforehand to make the grout removal easier.
For removing the existing grout, you could use a manual grout removal tool or a multi-tool fitted with a grout removal blade. Once the old grout has been removed, clean out the joints thoroughly before applying a suitable replacement grout. The best product will depend on the width and depth of the joints and how the pavers have been laid.
For cleaning the bluestone, I'd recommend using Peerless JAL 1L Deep Clean Slate and Hard Stone Cleaner. It's designed for cleaning hard stone surfaces and removing built-up dirt, grease and grime. Follow the manufacturer's dilution instructions, test it on an inconspicuous area first, then scrub with a stiff nylon brush and rinse thoroughly with clean water. I'd avoid acidic cleaners, as these can damage some natural stone surfaces. Make sure the pavers are completely dry before applying your sealer.
Once the grout has cured and the pavers are completely clean and dry, you can apply a natural stone sealer. Something like Berger Jet Dry Stone & Paving Natural Sealer would be worth considering. I'd recommend testing it in an inconspicuous area first to check the finish is to your liking.
Thanks Jacob
Here's a few images - it is a large area and includes pool coping. Note the staining - will the cleaner you have recommended deal with this?
Cheers Chris
Thanks for sharing the additional photos.
Looking at the staining, it appears that the stone itself may have been bleached or discoloured, rather than there being something sitting on the surface. If this is the case, the Peerless JAL Deep Clean Slate and Hard Stone Cleaner could help improve the appearance, but unfortunately, it's unlikely to remove the discolouration completely.
If you aren't happy with the results, you could also try a pH-neutral stone cleaner such as DTA Miracle Tile & Stone Cleaner from our friends at Beaumont Tiles.
Light pressure washing is another option worth considering, although you'd need to be careful not to damage the surface of the stone by keeping the wand at a reasonable distance from the stone and using a low pressure setting if available.
If the staining is actually discolouration within the stone, rather than surface contamination, cleaning products are unlikely to restore its original colour. However, giving the area a thorough clean would be a sensible first step before considering other options. Applying a suitable natural stone sealer afterwards may also help reduce the appearance of the bleaching by slightly darkening the stone and evening out its colour.
Ultimately, anything you do can help, but it is hard to say the extent to which it will remove the staining. I think a combination of the cleaning and sealing will do a good job of evening things out and reducing the prevalence of the staining, however.
