I am in the middle of enclosing my carport and need to fill a few gaps in a concrete block wall.
I will be installing flashing on the corner to cover the steel post, conduits, etc.
Question 1
As the flashing will not be wide enough to cover everything, I need to fill the area highlighted in yellow with something. My initial idea was to use a concrete mix, as I have some leftover concrete available. The issue is the steel bracket and bolt. I removed as much rust as possible, then treated the steel with Penetrol, followed by a coat of primer and paint. Given the amount of rust already present, I'm concerned that encasing them in concrete without extra protection (other than paint) may accelerate further corrosion.
I still have some Gripset Betta Bitumen Waterproofing Membrane left and was considering coating the bracket and bolt before filling the gap. What do you think? Is there a better approach or product I should use?
Question 2
I would also like to fill the area highlighted in purple to improve its appearance. My initial thought was to use the same concrete mix, but I'm concerned that it may not bond properly to the existing concrete surface.
What would be the best product or method for this repair?
Question 3
As you can see, there was a clash between the drain channel and the conduits, which required part of the drain channel to be cut away. I temporarily patched the area with a concrete mix, but I need a more permanent solution soon.
My first thought was to use silicone, but I'm not sure how durable it would be in this application. Another option would be to leave it as it is and coat it with Gripset Betta Bitumen.
Does anyone have any suggestions or recommendations?
Any help would be greatly appreciated.
