After putting a lot of time and effort into renovating my front lawn, this is the finished result!
The goal was to create a thick, healthy, consistent green lawn that complements the house and gives the whole front yard a much cleaner look. It’s been a project of getting the lawn back into shape, improving its condition and putting in the work to get it looking its best.
There’s something really satisfying about seeing the difference that a bit of time, effort and ongoing maintenance can make. I’m pretty happy with how it’s come up, and it’s great to finally have a front lawn I can be proud of!
Still plenty of plans for the garden, but for now, here’s the finished result. 🌿
Seasol (Seaweed)
Top Dress
Gypsum
Control release granular fertiliser
Saxon Lawn Levelling Rake
Saxon Core Aerator
Wheelbarrow
Shovel
Fertiliser spreader
Mower
Sprinkler + Hose
Assess the current situation (29.08.2026)
My Sir Walter Buffalo was looking pretty patchy and brown, and it hadn't received much love over the previous nine months. With excavators, cars and other machinery regularly driving over it during construction, the lawn had taken a fair beating.
My soil is also very clay heavy, so with all that traffic, compaction was a major concern. I knew that simply throwing some fertiliser at it wouldn't be enough to achieve the result I wanted. I needed to relieve the compaction, improve the soil structure and give the lawn a proper renovation if I was going to get it back to being thick, healthy and green.
Before tackling the renovation itself, though, I wanted to get the Buffalo growing again, so my first step was to give it a good feed with fertiliser to encourage some growth and get things moving.
(PS. pic was taken for my other project, but you can get an indication of the grass)
- Step 2:
Core aeration (05.09-12.09.26)
With the grass actively growing and the weather warming up, it was time to get stuck into the renovation. First up was core aeration, which was especially important given how compacted my clay heavy soil had become.
Core aeration removes small plugs of soil, relieving compaction and creating channels for air, water and nutrients to penetrate the root zone. It also gives the topdressing material somewhere to settle into, helping it work its way into the existing soil rather than simply sitting on the surface. This was an important step in improving the soil structure and creating a better foundation for a thicker, healthier lawn
This was easily the most tedious part of the whole process! I probably should have hired a machine, but instead, I tackled the entire lawn by hand over the course of two weekends.
Tip: Wear gloves! Your hands will thank you for it. 😅
Picture of my soil structure:
- Step 3:
Scalp the lawn (12.09.26)
Next up was to scalp the lawn, to do this use your mower on a low setting to remove excess leaf growth and dead material, helping tidy up the lawn and expose the surface for topdressing. It also helps encourage fresh growth and allows the topdressing to make better contact with the soil.
With Sir Walter Buffalo, though, you need to be careful not to go too hard. Buffalo spreads through above ground runners called stolons, so cutting too low can damage these runners and expose the stems, potentially leaving the lawn stressed, patchy and slow to recover. The goal is to tidy it up, not butcher it!
Bonus tip: Your mower can also save you a heap of work after core aeration. I used it to collect the soil cores left across the lawn, rather than having to pick them all up by hand. Much easier!
- Step 4:
Topdressing (12.09.26 yes was a BIG day)
This was one of the most important steps in the renovation. I ordered a bulk supply of a 90/10 sand and organic matter blend from a landscape supplier. My goal wasn't just to improve the soil, but also to gradually improve the levels across the lawn and create a smoother, more even surface.
I went with a sand-heavy blend because too much organic matter can break down over time, causing the surface to settle again. I wanted something that would help improve the soil structure while providing a more lasting improvement to the levels.
The process was pretty straightforward, but a bit of hard work! I filled a wheelbarrow, used a shovel to toss the mix evenly across the lawn, then worked it in with a lawn levelling rake to fill the aeration holes and smooth out the surface.
One important thing with Sir Walter Buffalo is not to smother it. Buffalo relies on its leaves to capture sunlight and keep growing, so burying the grass under a thick layer of topdressing can block out light, weaken the lawn and potentially cause sections to die off. I worked the mix down between the leaves and into the surface, making sure the grass blades remained exposed above the topdressing.
The key is to build up the levels gradually rather than trying to fix everything in one go. A little patience now should give me a much better foundation for a thick, healthy lawn heading into summer. 🌱
- Step 5:
Water in and Let Nature do its Thing!
Once the topdressing was spread and levelled, it was time to give the lawn a good water to help settle the mix into the surface and the aeration holes.
From here, the key is to keep the lawn consistently moist while the Buffalo recovers and starts pushing through with fresh growth. Just be mindful not to overwater or leave it waterlogged, particularly with heavy clay soil.
And that's the hard work done! Grab a beer, sit back and let spring and nature do their thing. With warmer weather, regular watering and a bit of patience, hopefully the lawn will reward all that effort with the thick, lush green finish I was chasing. 🍻🌱
- Step 6:
Mow & Maintain
Once you start seeing fresh growth coming through, you can get back into a regular mowing routine. The key is to let the lawn recover first, making sure the grass is growing actively and the topdressing has settled before getting the mower back out.
How often and how low you mow will depend on your desired height of cut (HOC). As a general rule, try not to remove more than one third of the leaf blade in a single mow. If you want a shorter lawn, mow more frequently and gradually bring the height down rather than taking too much off at once.
Regular mowing encourages the Buffalo to spread laterally, helping it fill in thin areas and develop a denser, more consistent finish. It also helps maintain an even height and keeps the lawn looking tidy. Just remember not to scalp Sir Walter Buffalo too aggressively, as it needs enough leaf to photosynthesise and recover.
Consistency is the secret here. A good renovation gives the lawn a fresh start, but regular mowing, watering and feeding are what help keep it thick, healthy and green. 🌱
Progress Pic:
- Step 7:
Current Pics
I still expect it to green up further as the season goes on. But she is looking tight, dark green and lush.
