Hi all,
I need some advice on dealing with severe rust and drainage issues along my roofline.
The bottom edge of my corrugated metal roof has completely rusted through just above the gutterline, leaving large deteriorated holes. I initially thought the gutter was just severely blocked by the thick layer of rusty debris. However, after checking the outlet, the downpipe pop is actually completely clear of blockages as in the last photo.
It appears the gutter itself has bowed or bent in the middle, directly below the worst of the roof rust. Because the gutter has lost its proper fall, water pools heavily in this middle section rather than flowing to the downpipe. During heavy rain, this stagnant water heavily overflows behind the gutter, pouring down and causing the paint on the timber fascia board to peel and blister.
I would appreciate your advice on the following:
- Rusted roof edge: Can these rusted bottom sections be patched or fitted with new apron flashing, or do the entire roof sheets need replacement?
- Sagging gutter: How do I best correct the fall of the gutter? Will I need to install additional brackets or entirely reposition the existing ones to fix the bow in the middle?
- Fascia repair: What is the recommended method to prep, treat, and repaint the water-damaged timber fascia once the leak is addressed?
- Materials: What specific flashing, brackets, sealants, or rust treatments from Bunnings would you recommend for this job?
Thanks for your help!
