Hello,
I am painting my bedroom and it has textured walls (not sure if it’s concrete or rendered brick?), which are already painted. I’ve cleaned the walls and plan to sand down some areas where there’s some bumps but otherwise, the walls are in good condition. I want to do a faux limewash effect so I’ll be using a brush for the top coats, but I want to apply undercoat (planning to use Taubmans 3 in 1) on the walls first.
For the undercoat, what type of nap roller + thickness should I be using considering there is a little bit of texture on the walls vs gyprock?
I am painting the walls and ceiling. I’ve attached a photo of the wall for the texture reference, hopefully that is clear (ignore the swatch, that’s not what I’m using).
Thank you in advanced!
