Hello,
My laundry sink is ~60mm diameter. Do you have plugs suitable for a sink this size?
Hi @mitch0816,
This https://www.bunnings.com.au/boston-large-white-multi-fit-ultra-grip-plug_p0493232 will suit an opening of 52-65mm, so it should work well with your sink.
Let me know what you think.
Hi Jacob,
Thanks for the suggestion. I purchased the https://www.bunnings.com.au/kinetic-50mm-basin-bath-plug_p4920229 yesterday before measuring the diameter of the waste opening.
I haven't actually removed it from the packaging yet, or tested it, but thought I may have bought an undersized plug. However, it seems as though the dimensions of the one you suggested and of the one I bought are fairly similar.
So, do you know whether the Kinetic plug is also compatible with 60mm waste holes?
Thanks,
Mitch
Given the similar size of the top, it could potentially work, however the shape might not be quite as conducive to a good seal.
As long as you take care to keep the packaging reasonably intact by making a clean cut that could be sealed, you could always return it if it is not suitable.
Okay, thanks Jacob. I will try that.
