hello! We have garden beds and some type of long grass is taking over and difficult to kill. We have tried nut grass poison and that did not work. Wondering if anyone can identify this grass and advise how to kill it? Can we use a poison or do we need to dig up the whole garden bed.
Hi @pen.lm,
It's difficult to identify the weed with 100% certainty from the photos, but it looks like it could be a variety of sedge. Allow me to tag @Noelle and @mich1972 to see if they can help identify it.
If it is a sedge, a product such as Sedgehammer may be effective, depending on the specific variety. However, without a positive identification, I wouldn't recommend using a selective herbicide, as we can't be certain it will work.
Given that it's growing through your garden bed, I'd lean towards manually removing it, making sure to dig out as much of the roots and any underground tubers as possible. It might take a bit of work, particularly if it's well established, but it's the safest option for protecting any existing plants. If you wanted to do this, I would suggest using a garden fork to break up the soil, then pull them out by hand taking as much of the root system as possible with it. Once the bulk of the grass has been removed, you can turn the soil using your garden fork, then plant out the bed and cover with a good thick layer of mulch at around 75-100mm thick.
If you couldn't manually remove it, you could carefully apply a non-selective herbicide such as Yates Zero directly to the weeds using a precision applicator. Just be aware that it can also damage or kill your garden plants if it comes into contact with them.
Personally, I'd start with manual removal, and depending on what you'd like to do with the bed afterwards, plant your plants, mulch the garden bed and then monitor the area for any regrowth. Weeds are inevitable, but with mulch to help suppress them and a bit of persistence, they aren't too difficult to control without the use of herbicides.
