I think I have found the problem that has caused it. How can I remove the eff. Salt residue. Some will sweep off but a a lot remain. What can I wash it with. Thank you.
Hi @shirley1231,
It's good to hear that you believe you have found and managed the source of the moisture. You'll just want to make sure that the moisture does not return, or it is likely the efflorescence will also return.
To remove the efflorescence, I'd suggest starting by using a scrubbing brush like this https://www.bunnings.com.au/oates-long-handle-deck-scrub-brush_p4460246 to remove as much of the loose material as possible, then vacuum it up.
For any more stubborn deposits, you can use an efflorescene remover such as https://www.bunnings.com.au/swp-e-r-efflorescence-rid_p0587486 or https://www.bunnings.com.au/crommelin-4l-efflorescence-remover_p0960128 ensuring you follow the manufacturer's instructions closely. Make sure to wear gloves, eye protection, enclosed shoes and protective clothing when using the cleaner.
You might also like to have a look at these previous discussions, which cover similar issues:
How to remove garage floor efflorescence, fill cracks and paint?
How to stop efflorescence on concrete?
