Laying tile underlay over floorboards where there is a 25mm gap between the end of the plank and bottom plate.
I’m laying tile underlay in my laundry as the base for click vinyl planks. The floor is Tassie Oak (laid 60 years ago). Most of the gaps between the end of the boards and the bottom plate are 10mm or less. But there are a few gaps of (20 or 25mm). See photos (I have added filler rod into the gaps). Visually, the plaster and skirting will cover the gaps. But is it OK to have the edge of the tile underlay hanging over this width gap? I can’t see any info on this in the installation manual.
Hi @Joynz,
It isn't ideal, but realistically due to the location and fact it will be covered by the wall sheeting and skirting boards, it won't be walked on so there is almost no risk of it breaking, and it will be covered so it won't be visible. The only real risk is that it could allow drafts to come through the floor, but that problem has been mitigated by filling the gap with foam filler rod.
As long as you install the tile underlay following the nailing pattern closely, ensuring that the edge nails are brought in enough so that they hit solid material rather than the gaps, then it isn't something to be particularly worried about.
Allow me to tag @Nailbag and @Dave-1 for their thoughts.
Good Evening @Joynz
Pretty much a repeat of what @JacobZ has said, once the wall is on plus skirting there will be minimal chance of a weak spot. My skirting board in my loungeroom had some gaps when I removed it to sand the floor, I didnt use filler rod (didnt know it existed back then :) ) but as soon as the skirt was back on, the problem was solved.
Hi @Joynz
As you have already sealed the filler rod then I can't see any issue at all covering that gap with tiles underlay. It will be well sealed from the subfloor especially once the walls are completed.
Nailbag
