My Shower screen door is broken and cannot be closed, is there a way to fix it DIY .
Or changing the door itself is the go, if that is the way, how much does it cost the minimum for the material and installation. Does Bunnings do it?
Hi @aj2025,
It appears that the corner bracket holding your shower door together has come loose. There's a visible screw that secures this corner, and it's possible the threads in the aluminium frame have stripped, allowing the screw to pull out.
If the screw has simply worked itself loose, you might be able to screw it back into position. However, if the threads have stripped, there's unfortunately no straightforward DIY repair, and this could indicate that the shower door is reaching the end of its serviceable life.
Shower screen doors are typically proprietary to their particular frame system, so finding a replacement door that fits your existing frame is unlikely. Even if one were available, it could cost almost as much or more than replacing the entire shower screen system.
Given the apparent deterioration, I'd suggest considering a complete replacement. Could you please provide the overall dimensions of your shower screen, including the door, surrounding frame and any fixed side panels? We can then look at the screen range to see what might suit your space.
Unfortunately, Bunnings doesn't offer a service for replacing shower screen doors or complete shower screens, so you'd need to engage a professional installer separately. Installation costs would depend on the replacement system and the work required.
Please be particularly careful around the shower glass, as toughened glass can shatter unexpectedly if its edges or corners are damaged. I'd recommend professional assistance if you're not confident handling it. If attempting to refit the screw, wear safety glasses, cut-resistant gloves, a long-sleeved shirt, trousers and enclosed footwear.
The door Size itself is 29 inch * 72 inch and the panel on which the door is fixed around 31inch * 74 inch
Many thanks for those measurements, @aj2025.
That puts your door at approximately 737mm wide x 1829mm high, with the surrounding frame measuring 787mm wide x 1880mm high.
Could you also let us know whether the shower screen has any additional fixed glass panels, and provide the overall width of the complete shower screen system? A photo showing the entire shower screen would also be helpful.
With those details, we can look at suitable replacement options from the Bunnings range.
Ok I will post some pics
Many thanks for the additional photo, @aj2025.
I can now see that your shower screen has a non-standard configuration, with a full-height glass panel extending down to the top of the bath, alongside a separate shower door.
Unfortunately, this makes finding a suitable replacement considerably more complicated. Most shower screens available off the shelf are designed for standard configurations, such as corner showers, alcoves or screens mounted directly onto baths. Your arrangement combines a full-height shower enclosure with a half-height section over the bath, which isn't something you're likely to find as a complete off-the-shelf system.
The difficulty is that the replacement would need to accommodate the bath's position and height, the full-height glass panel, the shower entrance and the existing wall layout. Even if we found a door with suitable dimensions, it wouldn't be compatible with the existing framing.
Have you tried reinserting the screw into the corner bracket? If so, were you able to get it to grip the frame and tighten the corner securely, or does it simply spin without tightening? That would help us determine whether the screw has just worked loose or whether the threads in the frame have stripped.
Ah ok, I think it simply spins without tightening, but moreover i have not tried it properly as i don't have adequate safety gloves to do the deed myself. i will get back to you when i have something more to say.
