Want to bring our front concrete steps back to life. Repair the cracks and paint them. I have already used weed killer and will give them a good clean. Looking for steps and products and tips! They are very old but in good structural condition.
Welcome to the Bunnings Workshop community @gc2026. It's wonderful to have you join us and many thanks for sharing your question on step restoration.
You should be able to give those steps a fantastic makeover with some repairs and a fresh coat of paint.
Once you've thoroughly cleaned the steps and removed any loose or deteriorating concrete, I'd recommend using https://www.bunnings.com.au/davco-5kg-136-rapid-patching-mortar_p0760336 to repair the cracks and damaged areas. It can be applied with a trowel to fill imperfections and restore the surface. For deeper cracks, you may need to build up the repair in layers, following the manufacturer's instructions.
Once the repairs have fully cured, you can prepare the steps for painting. I'd suggest looking at Dulux concrete paint range. Adding an anti-slip additive would also be worthwhile, particularly as the steps will become slippery when wet.
Before painting, make sure the surface is completely clean and dry, and follow the paint manufacturer's preparation and priming requirements. Two coats will typically provide a nice, even finish.
Here's a helpful step-by-step guide: How to paint concrete floors.
One thing I'd recommend is checking whether any of the cracks are still moving or widening. If they are, a rigid patching compound may crack again, and the underlying movement would need to be addressed first.
