My toilet cistern fills up but doesn’t stop filling. So it quietly overflows, down the overflow tube into the bowl. What could be causing this?
I think it is a Caroma M5 outlet valve. I have tried to turn the outlet valve anticlockwise to remove it so I can check the washer, but it does not turn. Concerned I could break the plastic.
I’ve tried to see how to check the valves in the inlet system, but it is difficult to access, possibly facing backwards because it is on the right side, and doesn’t quite match the video. The inlet valve seems similar to the Quietflow II, but not exactly the same.
What do you suggest?
