Hi.
I've just noticed this widening gap between my patio concrete and brick.
Looks like the foam has maybe disintegrated a bit or shrunk.
Whats the best way to fix this? Could this be a DIY or professional job?
Hi @NorIlyanaK,
The gap between your patio concrete and brickwork is an expansion joint, which allows the two surfaces to move independently as temperatures change. For this reason, you'll want to use a flexible sealant rather than filling the gap with a rigid material such as mortar.
I'd suggest starting by tidying up the gap, removing any loose mortar, dirt and debris with a scraper and stiff-bristled brush. Once the area is clean and dry, you can cover over the foam and fill the gap using Sikaflex 11FC Purform, which is a flexible polyurethane sealant suitable for use on concrete and masonry.
This should provide a flexible, weather-resistant seal while still allowing for some movement between the patio and brickwork.
For a step-by-step example of the process, have a look at my guide on How to fill a joint in a concrete slab. Although the situation is slightly different, the materials and application process are essentially the same.
