The journey to create our dream garden a place that would grow and change with us as a family - when we purchased our house the backyard area was full of potential, but not much else! A tired sloping lawn, old shed, heaps of concrete… but plenty of space to create… so away we went!
BEFORE PICS (2007)
Some products may have changes since install, but most similar follows…
Dynabolts
https://www.bunnings.com.au/ramset-10-x-75mm-dynabolt-plus-hex-nut-bolt_p2269422
Post stirrups
https://www.bunnings.com.au/vuepro-90mm-stainless-steel-bolt-down-post-support_p0389828
Joist hangers
https://www.bunnings.com.au/pryda-joist-hanger-to-suit-45-x-140mm_p0294197
Guttering
https://www.bunnings.com.au/icon-plastics-3m-pvc-gutter_p4775009
Galvanised bolts
https://www.bunnings.com.au/zenith-m10-x-120mm-hot-dip-galvanised-hex-head-bolts-and-nuts-each_p2448995
Griplock nails
https://www.bunnings.com.au/paslode-50-x-2-8mm-500g-griplock-galvanised-nails-170-pack_p2360352
https://www.bunnings.com.au/paslode-65-x-3-15mm-2kg-galvanised-griplock-nails-440-pack_p2360384
Polycarbonate roofing and accessories
https://www.bunnings.com.au/suntuf-3-0m-grey-polycarbonate-corrugated-roofing_p1015737
https://www.bunnings.com.au/suntuf-clearfix-roofing-screws-50-pack-50mm-50-pack_p1013426
https://www.bunnings.com.au/suntuf-access-25mm-x-20m-purlin-tape_p1010469
Treated pine decking, posts, bearers, joists, rafters
https://www.bunnings.com.au/90-x-22mm-decking-h3-treated-pine-l-m_p8032580
https://www.bunnings.com.au/search/products?page=1&q=treated+pine&sort=BoostOrder
Dulux Paint
https://www.bunnings.com.au/search/products?page=1&q=dulux+paint&sort=BoostOrder
Decking oil and accessories
https://www.bunnings.com.au/cabot-s-4l-merbau-aquadeck-exterior-decking-oil_p1520084
https://www.bunnings.com.au/cabot-s-decking-oil-applicator_p1660060
Levelling mix
https://www.bunnings.com.au/scotts-lawn-builder-20l-levelling-mix_p0938167
Topdressing
https://www.bunnings.com.au/scotts-lawn-builder-25l-organic-based-lawn-soil-topdress_p1097031
Rapid set concrete
https://www.bunnings.com.au/cement-australia-20kg-rapid-set-concrete_p0760078
Yellow tongue flooring
https://www.bunnings.com.au/structaflor-general-purpose-19mm-3600-x-800mm-mr-particleboard-yellowtongue_p0148884
Blueboard
https://www.bunnings.com.au/james-hardie-3000-x-1200-x-7-5mm-3-60m-hardietex-cladding_p0718217
Plywood sheets
https://www.bunnings.com.au/1200-x-596mm-9mm-plywood-pine-premium-bc-grade_p0390149
Plants - want lots more yet!
https://www.bunnings.com.au/products/garden/plants
Pots
https://www.bunnings.com.au/search/products?page=1&q=pots&sort=BoostOrder
Firepit
https://www.bunnings.com.au/glow-tambo-fire-pit_p3171835
Hammock
https://www.bunnings.com.au/marquee-double-polycotton-hammock_p0215109
Metal stools
https://www.bunnings.com.au/marquee-white-metal-bar-stool_p0314869
Cement sheet and cutters
https://www.bunnings.com.au/craftright-rubber-grip-handle-fibro-cement-sheet-cutter_p6010280
https://www.bunnings.com.au/james-hardie-2400-x-600-x-22mm-hardie-secura-flooring-sheet_p0851523
Garden shed
https://www.bunnings.com.au/absco-sheds-3-0-x-2-26-x-2-0m-zinc-double-door-garden-shed-with-anchors_p0657968
Laminate flooring
https://www.bunnings.com.au/floor-select-8mm-2-13m-radiant-oak-laminate-flooring-9-pack_p0975471
Liquid nails
https://www.bunnings.com.au/selleys-320g-liquid-nails-construction-adhesive_p1233751
No more gaps
https://www.bunnings.com.au/selleys-475g-no-more-gaps-interior-fast-dry-gap-filler_p1230089
Fertiliser
https://www.bunnings.com.au/garden-basics-3kg-all-purpose-npk-fertiliser_p0274290
https://www.bunnings.com.au/garden-basics-2-5kg-lawn-fertiliser_p0282394
https://www.bunnings.com.au/yates-4l-weed-n-feed-hose-on-lawn-weed-killer_p0121425
Weed killer
https://www.bunnings.com.au/yates-250ml-zero-triple-strike-garden-weedkiller-concentrate-250ml_p0376806
Lawn seed
https://www.bunnings.com.au/scotts-1-3kg-seed-feed-tough-lawn-seed_p0938166
https://www.bunnings.com.au/garden-basics-1kg-all-purpose-lawn-seed_p0274293
Building wrap
https://www.bunnings.com.au/ametalin-1350mm-x-30m-silverwrap-micro-perforated-md-vapour-permeable-reflective-wall-insulation_p0810480
Drill bits - various
https://www.bunnings.com.au/search/products?page=1&q=drill+bits&sort=BoostOrder
…most likely heaps of other bits and pieces I've forgotten!
Hammer drill
https://www.bunnings.com.au/xu1-500w-hammer-drill-xhd-501_p0800094
Drill
https://www.bunnings.com.au/dewalt-18v-xr-2-piece-combo-4-0ah-kit-dcz207m2t-xe_p0636631
Chisels
https://www.bunnings.com.au/trojan-3pc-chisel-set_p0479717
GMC dropsaw (no longer available I think)
Hammer
https://www.bunnings.com.au/irwin-16oz-fibreglass-hammer_p0065672
Handsaw
https://www.bunnings.com.au/bahco-ergo-superior-nxt-550mm-handsaw_p0117180
https://www.bunnings.com.au/irwin-plus-880-universal-handsaw_p0147223
Spirit level
https://www.bunnings.com.au/craftright-1200mm-spirit-level_p0396992
Set square
https://www.bunnings.com.au/craftright-250mm-try-and-mitre-square_p5660334
Tape measure
https://www.bunnings.com.au/craftright-8m-tape-measure_p5660481
https://www.bunnings.com.au/stanley-8m-26ft-imperial-tape-measure_p5660378
Knee pads
https://www.bunnings.com.au/saxon-knee-pads_p0721381
Rakes
https://www.bunnings.com.au/saxon-14t-fibreglass-garden-rake_p0701759
https://www.bunnings.com.au/cyclone-super-garden-rake_p3360560
https://www.bunnings.com.au/trojan-500mm-leaf-rake-steel-handle_p0684962
Soil leveller
https://www.bunnings.com.au/saxon-soil-spreader_p0701758
Shovels
https://www.bunnings.com.au/saxon-post-hole-long-fibreglass-handle-shovel_p0242871
Sledge hammers
https://www.bunnings.com.au/craftright-3-6kg-sledge-hammer_p0490018
https://www.bunnings.com.au/craftright-1-8kg-sledge-hammer_p0490019
Circular saw
https://www.bunnings.com.au/xu1-1200w-185mm-corded-circular-saw_p0011400
Sanders
https://www.bunnings.com.au/ozito-800w-belt-sander-bsr-7000_p6290503
Lawn mower - (model pre this version)
https://www.bunnings.com.au/ozito-pxc-36v-2-x-18v-335mm-lawn-mower-3-0ah-kit-pxlmk-3182_p0471940
After removing the smallest of old decks (which was only hanging on by a thread!) we set out to create a covered deck over the existing concrete which would include extended steps and platforms down to what would become the first of two level lawn areas.
- Step 2:
With the main deck complete, we set out to level the sloping lawn. The idea was to create two level lawn areas with a boardwalk running alongside to link the main deck with a future deck area that would house the clothesline.
To raise the level of the bottom tier, dirt (and clay!) was dug out of the existing old shed… I wanted to reduce the floor level in there to create enough depth for a golf hitting net!
The dirt was dug out by hand and wheelbarrowed to the bottom level (a few shovels broke in the process!)
We replaced the old weatherboards with blueboard during this time too.
- Step 3:
With the dirt removed from the shed and lawn levelled ready for turf, I doubled back to replace the shed floor at the lower level to allow for the golf net :)
The old timber floor was recycled to clad the walls of the new 'man cave'.
The man cave has evolved over the years!
- Step 4:
Topsoil added, and along came the turf (and so did the wife on the rake!)
- Step 5:
As the garden evolved over the years (and our family increased by one :) we added a water feature (in memory of our beloved Jack Russell, Josie) in a void space between the main deck steps and an existing hugely deep concrete slab… the slab would house a jacuzzi covered by a future open pergola.
As our taste changed, so too did the look of the deck/s… painted decking and changed the balustrade to vertical slats… painted white throughout to match the house as it was painted.
- Step 6:
A deck area for the clothesline was created at the same level as the lower level lawn for easy access.
An upper deck was also added (not at the same time, a few years apart… we just didn't take the progress pics!) to the original deck giving beautiful views over the city.
- Step 7:
Rustic firepit created, with recycled corrugated iron roof extension from the open pergola covering the spa… brilliant place to be on a rainy day!
- Step 8:
Creating a 'cubbyhouse' (built by us from scratch) for our daughter was a must as she got older (currently 12)… what began as a small 2x2m cubby has evolved to something a little more 'fancy', as has the early swing set to a Vuly setup which takes half my lawn!
- Step 9:
19 years on… I'm still adding to our dream garden (got to have a project) - looking forward to adding some arbours down the boarwalk as the final 'hard landscaping' piece, then continue to add plants and enjoy the garden as it evolves and grows…and there's always maintenance, painting etc which I love!
CURRENT 'AFTER' PHOTOS - 2026
