Hi everyone!
I recently purchased a second-hand French Provincial dresser from Facebook Marketplace. It is approximately 15 years old.
We’re preparing it for our nursery, and our main priority is to thoroughly clean it and get rid of the musty, old smell before using it.
There’s a yellow/mustard-coloured residue in several areas, particularly along the sides and underneath the drawers. When I wipe it with a cloth, the residue transfers onto it. We’re unsure whether it’s wax, built-up grime or something else.
The paint is also peeling in some areas, and we may consider repainting it same antique white colour later, but for now, we want to focus on cleaning and treating the dresser properly without damaging its original finish.
This is our first DIY furniture project, so we’d really appreciate advice on:
We’d love your recommendations for the safest and most effective approach. Thank you so much for your help! 😊
Hi @Deeanno,
Welcome to the Bunnings Workshop community. It is wonderful to have you with us.
Looking at the areas where the drawers slide, it appears that friction over time has worn away some of the existing paint, exposing the timber underneath. The yellowish residue could be a buildup of wax, oils or general grime, but it's difficult to say with any certainty. I wouldn't be overly concerned about it at this stage, as this kind of wear is fairly common in older furniture.
I'd suggest starting by cleaning all the surfaces of the dresser using a microfibre cleaning cloth dampened with warm water and a little mild dishwashing detergent. Just be careful not to use too much water, particularly around corners, joins and areas where the paint has worn away, as moisture can soak into the exposed timber and cause swelling.
If there is any stubborn residue, you could try gently lifting it away using a plastic scraper, keeping the blade almost flat against the surface to avoid scratching or damaging the finish.
For the musty smell, I'd recommend removing all the drawers and placing the dresser and drawers somewhere dry and well-ventilated for several days. Give the inside of the drawers, their undersides and the interior of the dresser a thorough clean, then allow everything to dry completely before putting it back together.
Once everything has dried, you could place a Cli-mate Sunsack Moisture Absorber inside the drawers to help manage any lingering moisture. If the smell persists, you could also consider using a product such as Britex Odour Blaster, following the manufacturer's instructions.
If you eventually decide to repaint the dresser, the general process will involve cleaning the surfaces, removing any loose paint, lightly sanding, applying a suitable primer and finishing with furniture paint. https://www.bunnings.com.au/diy-advice/home-improvement/furniture-upcycling/how-to-upcycle-almost-anything-with-paint , https://www.bunnings.com.au/diy-advice/diy-skills/painting/transform-your-decor-with-porters-paints-revive-furniture-paint and https://www.bunnings.com.au/diy-advice/diy-skills/painting/transform-your-decor-with-porters-paints-revive-furniture-paint will give you some guidance on the process. If there was anything specific about your dresser that you weren't sure about, please let us know and we can assist further.
You might also find @vividupcycling's Upcycled coastal-style timber dresser project helpful, along with @Nham's Bedside table makeover.
I'd start with a thorough clean and some time airing out the dresser, as there's a good chance this will make a noticeable difference. If the musty smell remains after that, let us know and we can look at some further options.
Let me also tag @prettyliving and @Herrenovacation to see if they have any recommendations or guidance they can offer.
