my charger stops charging after 2 red squares , the green light on the charger stays lit and says temperature fault
Is it safe or do I need a new charger
Hi @hoceyers.,
Welcome to the Bunnings Workshop community. It is wonderful to have you with us.
I would err on the side of caution and discontinue use. We don't really have enough information to determine whether the battery or the charger are the problem.
At this stage, I would suggest bringing your battery and charger in to your local Bunnings. The team at your local store's Tool Shop will have compatible batteries and chargers so you can determine whether the charger or battery is the cause of the issue.
If you have the receipts and they are still within their warranty period, they will be able to assist you with a replacement. If not, they will be able to determine what needs replacing, whether it is the battery or charger.
