When our house was built, there was a box on a post in the front yard. We thought it would be taken away once the house was built, but it wasn't. Instead of having a green dome holding the power, the Western Power put the box on a post. It would cost thousands to get the Western Power box relocated so we came up with a solution …. we would disguise it by turning the eyesore into an attractive feature. The ugly grey box became a pretty Birdhouse!
https://www.bunnings.com.au/wattyl-4l-monument-low-sheen-pre-tinted-solagard-exterior-paint_p0630316
https://www.bunnings.com.au/mont-marte-16-piece-x-36ml-acrylic-paint-set_p1158006
https://www.bunnings.com.au/white-knight-310g-crystal-clear-satin-clear-acrylic-spray-paint_p1583972
- Some left over wood moulding
First of all I got the dimensions of the box and on graph paper and drew the box. Using coloured pencils I created a mock up of what I wanted the box to look like. This is a photo of what the box initially looked like pre makeover.
- Step 2:
UNDERCOAT
I chose to paint the box and post with Wattyl Low Sheen Pre-tinted Solagard paint in the Monument colour as it is a tough and durable exterior paint which offers protection in any weather or climate. It also has a warranty against flaking, peeling or blistering which is fantastic when you live by the coast. Monument was chosen as it was the colour of our Colorbond Roof and wall.
- Step 3:
PAINT
I used acrylic paint to paint the design on the box making sure that the paint was applied liberally. Some areas I did 2 coats to ensure it had a good covering.
- Step 4:
PROTECTION
Last of all, I glued two pieces of some left over wood moulding onto the front to give the illusion of a pitched roof. This was attached using wood glue and then painted Monument, the same as the post and top of the box.
To protect the paint, I sprayed the entire box and post with White Knight Crystal Clear Acrylic Spray Paint. This should extend the life of the finished paint job.
- Step 5:
THE RESULT
We get so many lovely comments about our 'Birdhouse' from people walking past. It definitely shows that with a bit of effort and creativity, an eyesore can be turned into a beautiful garden feature.
