My outdoor faucet is dripping. I closed it tightly but still dripped. Do I need to change the valve or the while faucet? I am newbie with this. What should I do? And where can I find the main valve to close the water going this line?
Hi @japbrizuela,
If the water is dripping from the spout even when the tap is turned off tightly, it typically indicates that the washer inside the tap has worn out and needs replacing. The good news is that you likely won't need to replace the entire tap.
The washer sits inside the tap's valve assembly and creates a seal when you turn the handle off. Over time, this washer can deteriorate, allowing water to continue passing through.
Before attempting any repairs, you'll need to locate and turn off your property's main water supply. The water meter and shut-off valve are typically located near the front boundary of your property, often close to the footpath or nature strip. They might be inside a small ground-level meter box or partially concealed by plants. If you're having trouble locating yours, your local water authority should be able to assist.
Once the water supply has been isolated, the tap handle and valve assembly can be removed using suitable tools, such as an adjustable spanner, to access and replace the worn washer. It's also worth inspecting the valve seat, as damage or corrosion can prevent a new washer from sealing correctly.
Given that you're new to this type of repair, I'd recommend engaging a licensed plumber to replace the washer. Plumbing regulations vary between states, and repairs to taps connected to the mains water supply may require a licensed professional.
In the meantime, avoid overtightening the tap handle to stop the dripping, as this can damage the internal components and make the problem worse.
