The best approach is always to replace a cracked tile.
However, if you want to temporarily cover the damaged area of the tile, I suggest using Selleys 50g Knead It Multi Purpose Epoxy Putty.
Your goal is to fill the damage and level the surface of the putty to the same level as the tile. This will save you a great deal of sanding effort.
Once the surface is level, I suggest painting the repair spot with a sample paint pot of the same colour as the tile. It will disguise the damage for a while, but you'll need to touch it up every now and then when the paint starts to fade away.
Please keep in mind that it will be necessary to replace the broken tile eventually, as the damage will slowly get bigger. - EricL
It is sometimes possible to conduct repairs to minor cracks in tiles; however, there is no way to effectively repair a structural crack that extends the whole way through the tiles from one side to the other. Unfortunately, they will need to be replaced.
Structural cracking occurs when there are gaps beneath the tiles, often because of poor coverage of tile adhesive. When replacing the tiles, you need to ensure there is uniform coverage of tile adhesive beneath the tiles. This is done by applying the tile adhesive with a notched trowel. - JacobZ
I had a hairline crack like this in some tiles at my old house and I rubbed some paint that was the same colour as the tile into the crack and wiped off the excess before it dried and it worked really well at disguising it.
Over time (about six months or so) it turned dark again but then I just repeated the process - it only takes a couple minutes. There’s probably a more permanent method but this worked really well for me. - prettyliving
When using a filler, apply only enough of the product to fill the depression without leaving the filler proud of the surface. This can be done with a plastic scraper.
Ideally, you do not want the filler above the tile surface as that will require sanding, which would be difficult given you could mark the tiles. If you need to sand the product back to be flush with the tile, I suggest you tape up around the filler to offer some protection to the tile. - MitchellMc
