PVC moulding inside, it will be visible in the final use. Isopropyl Alcohol does not seem to take it off, ie cloth gets some ink smeared on it but hardly coming off PVC
Also got acetone or mineral turpentine
Also have acetone or mineral turpentine
Hi @bara3,
Is this one of our PVC mouldings, and do you happen to know the manufacturer or product name? If so, we could reach out to the manufacturer to see whether they have a recommended method for removing the printing.
I'm presuming it's a barcode or product identifier printed onto the moulding. Typically, this would be on the reverse or non-visible side, but I understand that in your situation, it's going to be facing outwards.
You could try mineral turpentine on a small, inconspicuous test section first to ensure it doesn't affect the PVC. I'd be particularly cautious with acetone, as it can damage or soften PVC, so I wouldn't recommend using it without confirmation from the manufacturer.
The fact that you're getting some ink transferring onto the cloth with isopropyl alcohol is actually encouraging. It suggests you're successfully removing at least some of the printing. It might simply be a matter of continuing with fresh sections of cloth until you've removed as much as possible.
Depending on the printing process, some of the ink may have penetrated the surface, making complete removal difficult.
Let me know the manufacturer or product details, and we can investigate further.
https://www.bunnings.com.au/brutus-19-x-19-x-2-5mm-2-4m-pvc-building-moulding_p1100622
the mineral turpentine also doesn't do anything either, possibly even less than the isopropyl alcohol
at the rate it's coming off with isopropyl alcohol it might take a long time to get it
the actual barcode does not look like it has lightened at all
I don't really understand why they print these barcodes in such strong ink
using to make a channel for my honeycomb blinds
I'm really sorry, but I've contacted the manufacturer to see whether there's a way to remove the printed barcode, but unfortunately, they aren't aware of any products that will successfully remove it.
The moulding is actually designed to be painted, which would normally cover the printing. However, I completely understand that you're after a white moulding for your honeycomb blinds, and having to paint an already white product would be disappointing.
One option you could try is lightly sanding the printed area with some 240-grit sandpaper. Depending on how deeply the ink has penetrated the surface, you might be able to remove it this way. Just be aware that sanding could affect the surface finish, so I'd recommend testing a small section first.
I'm sorry I couldn't offer a better solution. If the product isn't suitable for your needs, our team in-store would be happy to assist you with a return.
what is recommended for painting on this? I read that PVC does not take paint unless you prepare it with a lot of work.
also I find that the PVC does not block light coming through it merely diffuses it a little bit. Since paint does not seem to work, what if I bought black tape and stuck it to the side facing the outside?
What would you recommend as the way to make this block the light. I would prefer to use something white rather than black if possible to match window and walls
Hello @bara3
I suggest looking at using https://www.bunnings.com.au/t-rex-48mm-x-9-1m-white-ferociously-strong-duct-tape_p0593957 as it is UV stable and can be used for outdoor applications. If you were to paint it, I recommend sanding the surface very well and using https://www.bunnings.com.au/dulux-1l-precision-white-maximum-strength-adhesion-primer_p1400848 then painting it with your preferred topcoat. Please note that there is no guarantee that the paint or tape will provide a full block out of light shining on it.
