I can’t remove old toilet seat any help would be aporeciated. I think the bolt keeping it in is rusted and I can’t turn the bolt at the bottom
Hello @amnie99
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your toilet seat.
I suggest spraying the entire bottom assembly with https://www.bunnings.com.au/wd-40-175g-multi-use-smart-straw_p6100413 and let it soak for a few minutes. I then recommend using a https://www.bunnings.com.au/craftright-250mm-multi-grip-plier_p0154795 on the plastic nut and forcing it off. Please make sure to wear personal protection such as rubber gloves and goggles when working on your repairs.
If the nut is still difficult to move, I propose using a https://www.bunnings.com.au/xu1-2000w-heat-gun-xhg-504_p1025329 to soften the plastic nut. Once the plastic is soft you should be able to twist it off the post. My last suggestions is to use a https://www.bunnings.com.au/trojan-300mm-mini-hack-saw_p0191082 to cut the sides of the plastic nut which will allow you to remove it off the post.
Here is a handy step-by-step guide: How To Replace a Toilet Seat
