Cockroaches can quickly become a nuisance once they've established themselves inside your home. They contaminate food, spread bacteria and are experts at hiding in dark, sheltered spaces.
The most effective way to eliminate them is to combine good housekeeping with sealing entry points and using the right pest control products.
Remove cockroach food sources and hiding places.
Start by removing anything that could attract cockroaches. Thoroughly clean areas such as under sinks, inside cupboards and behind appliances. Remove any food scraps, grease and spills that could provide a food source.
Cockroaches are also attracted to moisture, so have any leaking taps and pipes repaired, wipe down wet surfaces and avoid leaving water in sinks overnight. Store food in sealed containers, empty rubbish bins regularly and remove unnecessary cardboard boxes and clutter that can provide hiding places.
- Step 2:
Seal gaps to prevent cockroaches entering.
While you're cleaning, keep an eye out for places where cockroaches may be getting into your home. Check around plumbing pipes under sinks, behind kitchen and bathroom cabinets, around wall vents and anywhere pipes pass through walls or cabinetry.
If you find any small gaps or cracks, seal them with your gap filler or sealant. Check that door seals and flyscreens are intact, as cockroaches can squeeze through surprisingly small openings. Avoid sealing ventilation openings or drainage points that need to remain functional.
- Step 3:
Apply outdoor cockroach barrier spray.
Once you have reduced potential access points, apply a residual barrier spray around the exterior of your home. This creates a protective barrier designed to help control cockroaches before they have an opportunity to enter the house.
Pay particular attention to areas where cockroaches are most likely to gain access, including around external walls, doors and windows, plumbing penetrations, and other gaps or potential entry points.
Remove leaf litter, accumulated debris and other hiding places close to external walls to make these areas less attractive to cockroaches. Always follow the manufacturer's directions, including what personal protection equipment to wear, where the product can be applied, drying times and recommended re-application intervals.
- Step 4:
Use cockroach spray indoors.
After creating an external barrier, use a suitable indoor crawling insect spray to treat areas where cockroaches are most likely to hide and travel. Focus on cracks and crevices, behind and beneath appliances, under sinks, along skirting boards and around plumbing penetrations.
Cockroaches are most active at night, so checking these areas with a torch after dark can help identify where they're hiding. Avoid spraying food preparation surfaces, electrical appliances and areas where bait stations will be placed. Always follow the product's safety instructions, including ventilation requirements and precautions around children and pets.
- Step 5:
Place cockroach bait stations.
Bait stations are an effective way to target cockroaches that remain hidden after spraying. Cockroaches consume the bait, which can also help control other cockroaches in their hiding areas, depending on the product.
Position bait stations beneath sinks, behind the fridge, beside the dishwasher, inside cupboards and anywhere you've noticed cockroach activity. Place them close to walls and sheltered areas where cockroaches naturally travel, rather than in the middle of open spaces.
Avoid spraying insecticide near bait stations, as this can discourage cockroaches from approaching them. Keep stations out of reach of children and pets, and replace them according to the manufacturer's recommendations.
Continue to keep your home clean and inspect for signs of renewed activity over the following weeks. Reapply the external barrier spray and replace bait stations as recommended by their manufacturers. If you're regularly seeing large numbers of cockroaches, particularly small ones in kitchens and bathrooms, professional pest control may be necessary to eliminate an established infestation.
