This is a 1980s balcony and we want to repaing it however, we need to do something to the bottom corner before we are able to paint.
Hi @Brit26,
The best way to address the issue really depends on a couple of factors.
Firstly, we'd need to know if the timber is doing anything structural, or if it is simply there for aesthetics. Given I can see what appears to be bolts going through the beam and then through the posts, I suspect it is structural in nature. To confirm this, could you take some photos from under the deck showing how the timber is connected to the posts and if the joists are directly connected to it.
These are your joists here -
If it is bolted to the posts and the joists are connected to it, then it is almost certainly structural in nature. If that is the case, then unfortunately, you'd need to contact a builder or carpenter for assistance as the rot cannot simply be cut off or filled. The beam would need to be removed and replaced. This would require the rest of the deck to be supported so the beam can be removed then replaced with all the relevant structural connections reinstated.
If the beam is purely aesthetic in nature, there may be a simpler option, but given what I am seeing, we would need to be confident it is not structural for that to be an option. If you can provide some photos showing beneath the deck, we could have a better idea of what we're working with, but I'd still suggest contacting a builder or carpenter for a proper on site assessment.
Let me know what you find.
thank you Jacob! I’ll attach the whole photo!
