This 1m cornice pops out a bit, how hard to replace the cornice and repair the 1m wide ceiling crack with expansion joint (I am fairly handy).
Hi @oasis1frog,
Both repairs should be fairly straightforward, assuming the plaster is still firmly attached and there is no ongoing movement causing the damage.
For the damaged cornice corner, I'd recommend using Gyprock Cornice Cement. Start by scraping away any loose or crumbling plaster and removing dust from the area. Mix up a small amount of cornice cement following the manufacturer's instructions, then apply it using a small joint knife. Build up the damaged corner in layers, shaping it to match the existing cornice profile. Once dry, sand it smooth, then prime and paint.
You might like to check out How to repair crumbled away cornice and How to repair a cracked cornice for some examples of similar repairs.
For the straight crack in the ceiling, I'd recommend using fibreglass mesh tape and Gyprock Less Mess Multi-Purpose Joint Compound.
Start by using a utility knife to open the crack slightly into a V shape, removing any loose plaster and dust. Apply the self-adhesive mesh tape centrally over the crack, then use a broad knife to cover it with joint compound. Feather the compound out on either side of the tape to blend the repair into the surrounding ceiling.
Once dry, lightly sand the area and apply a second, wider coat of compound. Finish by sanding smooth, priming and painting.
You might also like to have a look at How can I fix cracks in walls, cornices and ceiling? and How to repair cracks on the wall, ceiling and cornice? for similar discussions.
Keep in mind that if the cracking is caused by ongoing movement, it may return unless the underlying issue is addressed.
Let me know if you have any questions.
Thanks Jacob, appreciated.
