Does my woolly bush have a problem? I bought it last week from Bunnings and it is still in the same pot? I’m concerned that it may have a fungus or is being attacked by a bug.
Hi @Woolly,
Nothing is jumping out at me as being particularly concerning with your Woolly Bush. If there is anything in particular that looks fungal, or you spot any insects, can you grab a closeup and upload them so we can have a look?
I wouldn't be too concerned, but plants can experience a bit of stress when they're moved into a new environment, which can cause some short-term issues while they adjust. There does appear to be a little bit of leaf drop, but nothing that I'd be overly worried about at this stage.
For now, I'd suggest keeping an eye on it and making sure it's getting enough sunlight. Woolly Bush grows best in full sun, so ideally, it should be receiving at least 6 hours of direct sunlight each day.
It's also important to get the watering right, as Woolly Bush prefers well-drained soil and doesn't tolerate being waterlogged. You can check the moisture by pushing your finger about 5cm into the soil. If it still feels damp, hold off on watering. If it's dry, give it a thorough watering and allow the excess water to drain away.
Check out @Noelle's guide on How to diagnose a sick plant to get an idea of what to look out for over the coming weeks.
If it does take a turn for the worse, rest assured that you'll be covered by our Perfect Plant Promise.
