Removed shelves that had been screwed directly into the wall and then painted over. What products are best for patching the holes ready for painting?
Hi @Ambrosia,
Could you let us know roughly how deep the damaged sections of plaster are? This will help determine whether an all-purpose compound would be suitable or if a different product might be needed for deeper repairs.
As with your other question about textured paint in your home, given the age, you'll want to have it tested for asbestos and in this case lead paint. It is not worth the risk when simple testing options are available.
To start with, you'll want to carefully remove any loose or crumbling plaster until you reach a solid surface. A paint scraper would be handy for this, as you can also use it to apply and smooth the patching compound afterwards. Once you've tidied up the damaged area, give everything a thorough brush down with a stiff-bristled brush to remove any dust and loose particles.
I'd then suggest applying Bondall BondCrete, diluted to the bonding mix ratio specified on the packaging. This will help seal the porous old concrete, reduce moisture being drawn out of the repair compound too quickly and improve adhesion between the existing surface and the new material.
Once the surface has been prepared, you could use an all-purpose joint compound to fill the damaged sections, applying it in thin layers and allowing each coat to dry before adding the next. Apply the first coat to fill the damaged sections, keeping it as smooth as possible, then allowing it to dry. You can then apply a second coat that goes much wider than the first to help blend the repairs in with the rest of the wall.
The trick with plastering is to go wider than you would expect. Many beginners think that applying plaster to a narrower area means it will be less visible, when in fact it makes the edges much more noticable. By going wider, you give yourself more room to feather out the patch and blend it into the rest of the wall. This is why I recommend doing it in at least two coats. One to fill the damage, the second to blend it in.
Once the compound has dried, sand it smooth so it blends into the surrounding wall, then apply a suitable primer before painting.
