Hi there,
I want to build a 3-sided frame with a door out of merbau to make into a catio.
I haven't worked (successfully) with timber before, and want the construction to be as simple as possible. I do have an impact driver and a drill.
I want a full-height door to the front-right of the structure, but happy for reccomendations on what the width should be. Needs to be wide enough to comfortably accommodate regular use by people, as the catio will be enclosing the house's front entrance.
My struggles are knowing how much timber I need and in what thicknesses, what lengths to cut all the pieces at (measuremens provided are for the outside dimensions), what types of screws and fittings I should use and the correct process to follow when screwing everything together (previous attempts with timber have resulted in split wood, snapped screws and snapped drill bits).
My priorities with the build are being simple to put together while still being secure and stable. This is a rental, so the structure cannot be attached to the house or deck below in any way, but I can add sandbags or the like if needed. I'm also on a budget when it comes to the consideration of thickness of the timber pieces, however merbau is a must for me.
Additional info: I am scared of mitred corners and wish to avoid
