This latch on my kitchen window is jammed. Normally I would push on it to slide the window open but somehow I’ve managed to jam it shut. It is usually higher up the window.
Any advice gratefully accepted.
Hi @Tywoodpk,
It looks like the window handle might have slipped down and become jammed in the groove of the frame.
I'd suggest trying to lift the whole window upwards slightly. This might be enough to free the handle so you can simply lift it back into position.
Alternatively, you could try placing a cloth over the frame to protect it, then gently using a flathead screwdriver to lever the handle upwards. Just be careful not to apply too much force, as you don't want to damage the handle or frame.
Also take extra precaution when working around glass as one slip of your tool can cause it to shatter. Make sure to wear long protective clothing, gloves, enclosed shoes and eye protection while working around glass.
Give these options a try and let me know how you go.
Thank you so much! I will give it a go.
