I want to cast concrete pavers 30mm thick onto a concrete driveway that’s already made. Will they stick to the driveway when dried ?
Hello @Zanart21
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about casting concrete pavers on your driveway.
Covering or resurfacing your concrete driveway to revive it is a great idea. However, I wouldn't recommend pouring a 30mm layer of standard concrete or in a paved format over an existing driveway, particularly if it will be used regularly by vehicles. Although the existing driveway provides a solid foundation, a 30mm concrete topping is relatively thin and has a high risk of cracking, particularly under the concentrated weight of vehicle tyres.
The main concern is that standard concrete contains aggregate, and at just 30mm thick, there isn't sufficient depth to accommodate conventional reinforcement or provide much resistance to movement. If the existing driveway has cracks, expansion joints or slight movement, these can transfer through to the new concrete surface. Poor adhesion between the old and new concrete can also cause the topping to separate, crack or break away.
If your existing driveway is structurally sound and you're simply looking to refresh its appearance, I'd propose painting the surface instead with https://www.bunnings.com.au/dulux-10l-white-tint-satin-concrete-and-paving-coloured-sealer_p0417956 along with the appropriate primer and etcher.
Alternatively, if you're really keen at raising the driveway level by 30mm, I'd recommend consulting a professional concreter about a suitable concrete topping system. A thicker reinforced overlay may be another option, although this would require more height.
Please remember to wear personal protection such as gloves, goggles and a mask.
Thanks for your advice
