Built a 6m Kwila board walk to join two Kwila decks already built in previous projects.
Pine decking beams 145 x 45
Poles: 100 x 100
Kwila decking - 140 x 19 cut to size 600
Nut and bolts for joining board walk modules
Decking screws: stainless steel
Mikata Compound sliding mitre saw
Bosch Table saw JTS 10J
Two sets of Bosch Blue drill and drivers
Petrol driven hole borer machine
Measure area - 6m
Dig holes 90cm apart
Cut poles - and L shape cut top of pole to acommodate decking beams
Build 3 modules - boardwalk frames 3m x 60 cm wide
Attach poles to frames. Place in holes - check for square and cement in modules
Join 3 modules to each other using deck framing timber and nuts and bolts.
Cut Kwila to size - 60cm lengths
Pre drill holes at both ends of Kwila
Install Kwila onto decking frame using stainless stell screws.
After 2 weeks after Kwila cures apply decking oil.
