Hi Guys
I'm currently installing double-glazed aluminium sliding doors to enclose my existing patio, but I've run into an issue with the concrete floor being uneven.
The concrete gradually slopes down towards the right-hand side, near the patio post, with a height difference of more than 20 mm.
To keep the sliding door frame level and ensure the doors slide smoothly, I've temporarily used timber wedges and blocks underneath the bottom frame, as shown in the attached photos.
However, I'm looking for a more permanent and reliable solution.
I'd appreciate some advice on the following:
What is the best way to permanently level and support the aluminium sliding door frame on uneven concrete?
Would non-shrink grout, levelling mortar, or another material be suitable for filling the varying gaps underneath the frame?
How can I ensure the entire bottom frame is properly supported without causing it to bend or affect the sliding mechanism?
What would be the best way to waterproof the bottom of the frame to prevent rainwater entering underneath the doors?
Is there a suitable product available at Bunnings for this type of installation?
Ideally, I'd prefer a solution that doesn't involve cutting or removing the existing concrete.
I've attached a few photos showing the current installation, concrete slope and temporary timber supports.
Any suggestions, product recommendations or examples from someone who has dealt with a similar situation would be greatly appreciated.
Thanks in advance for your help!
