I am looking for advice on how to fix a water leak at the top of a window frame (photos attached). I would also appreciate recommendations on the best method to repair the cracks adjacent to the window.
Sorry, forgot to attach the photos in my post.
Hi @emmab1986,
Thanks for uploading those photos.
I can see there's quite a bit of cracking and deterioration of the plaster directly above the window frame, particularly along the junction between the frame and the wall.
When repairing water leaks, the first step is always to identify where the water is entering from outside. There's little point repairing the internal damage until the source of the leak has been located and resolved, as the problem will likely return.
I'd recommend starting with an inspection of the exterior above the window, paying particular attention to the flashing, sealant and any gaps or cracks that could be allowing water to enter. Keep in mind that water can travel along building materials before appearing inside, so the entry point might not be directly above the damaged area.
If you could share some photos of the outside of the window and the surrounding wall, we might be able to identify potential entry points. Otherwise, I'd recommend engaging a leak detection specialist or a professional experienced in window flashing to investigate.
Once the leak has been repaired and the area has dried out completely, you can turn your attention to the internal damage. Provided the underlying materials are sound, this should largely be a cosmetic repair involving removing loose and damaged plaster, filling the affected areas with a suitable repair compound, sanding, priming and repainting. Any plaster that has deteriorated beyond repair would need to be replaced.
The important thing is to resolve the source of the moisture first, rather than simply filling the cracks and painting over them.
Here's a helpful step-by-step guide: How to fill cracks in plaster walls.
Let me tag @oasis1frog, @SteveC, @lm4 and @HReno to see if they have any thoughts.
Hi @MitchellMc ,
Thanks for your response and for providing such detailed advice!
I have two photos on hand at the moment showing the window head leak from outside (see below). A trade recently fixed the window frame: the top one is the fixed window; the bottom one is the old window. I look forward to hearing your thoughts.
Looking at the exterior, I can see several cracks in the rendered section above the window, along with some gaps and deteriorated areas around the top of the frame. These are potential entry points for rainwater and should certainly be addressed.
I'd recommend starting by repairing the cracks and holes in the render above the window. This is something you could potentially tackle yourself using a suitable exterior masonry repair compound, provided the surrounding material is sound. Here's a helpful guide: How to repair a rendered wall.
I'd also suggest considering the installation of a drip edge along the bottom of the rendered section above the window. This would help direct rainwater away from the window frame rather than allowing it to track underneath the render and potentially find its way inside. A drip edge is a small groove or projecting lip along the underside of a horizontal surface that prevents rainwater from tracking back underneath it. Instead, the water collects at the edge and drips away from the wall or window frame, helping prevent moisture from entering the building.
The window and surrounding framework appear to be quite old, and some aspects of the installation are questionable by modern standards. There are several areas where water could potentially enter, so I'd recommend having a professional who specialises in window installations assess the frame, flashing and weatherproofing. They should be able to advise what improvements are needed to ensure the window is adequately protected from the weather.
One thing I'd also like to clarify is whether you're currently experiencing an active water leak, with water or dampness appearing inside during rainfall, or whether you're primarily concerned about the cracking and deterioration above the window.
If there's no evidence of active water ingress, it's possible that some of the internal cracking is related to movement rather than moisture. In that case, once you've confirmed the exterior is adequately weatherproofed and the surrounding materials are sound, you could potentially proceed with repairing the internal plasterwork.
I'd start with the exterior render repairs and an assessment of the window's weatherproofing before spending time on the internal cosmetic repairs.
@MitchellMc Thanks! Would you suggest using silicone to fix the missing mortar? What should be done?
Are you referring to the mortar between the bricks, or the cracking in the render above the window?
Regardless, I wouldn't recommend silicone for either, purely for uniformities sake.
If you are referring to the cracked render above the window, I'd suggest v grooving the cracks to widen them, then using the https://www.bunnings.com.au/polyfilla-500g-exterior-brick-and-render-masonry_p1210565 . @Nailbag goes through the process in his guide on How to repair a rendered wall, so have a read and let us know if there are any particular aspects that you need clarification on.
If you are referring to the missing mortar between the bricks, I'd suggest repointing them using standard mortar. Start by using a https://www.bunnings.com.au/masterfinish-small-poly-wheel-raker_p0538600 to rake out the damaged mortar between the bricks. You are aiming to give yourself a depth of about 20mm which can then be filled with fresh mortar. After raking out the mortar, use a soft brush to remove any dust or debris from the mortar lines. Once you've raked out and cleaned up the joins, mix up your mortar to a toothpaste consistency, then press the mortar into the seams using a https://www.bunnings.com.au/hyde-13mm-tuck-pointing-trowel_p0960298 . Allow the mortar to set up for 10 or so minutes, then go over it with a https://www.bunnings.com.au/kango-10mm-13mm-brick-jointer_p0098439 to smooth it out and remove any excess mortar. This will give you a nice uniform repair.
Thanks Jacob!
