The below stains have come from doormats that have gotten wet and have damaged the Unselaed concrete.
Have tried degreaser, detergent and high pressure cleaning which none have worked.
Anyone got any ideas? Concrete driveway is 4 months old.
Hi @KD72,
It looks like moisture trapped beneath the doormats has caused some discolouration of the concrete, potentially by drawing our dyes from the material. Given that you've already tried degreaser, detergent and pressure cleaning without success, I suspect the staining may have penetrated the porous concrete rather than simply sitting on the surface.
Before trying anything further, I'd suggest allowing the area to dry out completely for several days and checking whether the discolouration improves. If moisture has been trapped in the concrete, it can take some time for the appearance to return to normal.
If the staining remains, you could try a dedicated concrete cleaner, testing it on a small, inconspicuous section first. However, if the marks are caused by dyes or other materials leaching from the mats into the concrete, a general cleaner may not be particularly effective.
One thing worth considering is that your concrete is only four months old. I'd be cautious about using strong acids, aggressive chemicals or further high-pressure cleaning, as these could permanently alter the surface and leave you with an even more noticeable patch.
Can you tell us what the doormats were made from? Were they rubber-backed, or did they have some type of coloured fabric underneath? This might help us determine whether we're dealing with moisture discolouration, dye transfer or a reaction with the concrete.
Hi Mitchell
Thanks for the info, the mats were rubber/plastic backed.
However they did have colouring in the fibre part of the mat, however the stains look a bit like from the backing as well as the colour.
See below pic
Thanks Mitchell :)
Thanks for confirming. It certainly sounds like some of the colouring or material from the rubber backing has transferred into the concrete.
You could try giving the area another scrub with warm, soapy water and a stiff-bristled brush. If the staining has only penetrated the upper layers of the concrete, repeated scrubbing might help lift some of it. It may take several attempts to see an improvement.
Apart from that, I'm not aware of a product that can reliably draw staining back out of porous concrete once it has penetrated the surface. You could try a dedicated concrete cleaner, but I'd recommend testing it in an inconspicuous area first.
I'd avoid anything too aggressive, particularly given how new the concrete is, as you don't want to damage or discolour the surrounding surface.
