Hi all,
I have a old Caroma Dual flush (Uniset ) cistern. I attached a number of photos taken during dismantling and for illustration. My humble apologies for many photos and the Bunnings workshops system did not sequentially uploaded them sequentially (first in first out). Basic steps taken to change the seating washer/valve:
1. Turn off the water supply to the cistern. Flush the toilet to drain water in the cistern. Remove the cover.
2. Unscrew two right hand side front screws attached to the dual flush push buttons assembly.
3. Remove the float (by removing the L-shape pin on the top of Inlet valve. Remove the plastic tube around the water inlet valve
4. The seating (outlet) valve with its assemble including the square plastic tube is exposed (this is similar to a toilet plunger). The bottom of the assembly (valve seat that is firmly fixed the outlet flush hole) has three equally spared lugs/catches. To remove the plunger (seating valve /seal assembly), Gently turn anticlockwise, so that the the lugs/catches move into the bigger spaces of the holes of of the upper assembly (plunger) where the seating valve is attached. Pull gently upward and the plunger will be disengaged.
5. Change the bad washer (black one) with the new one. I used Kinetic Cistern Repair kit from Bunning (similar internal and outer diameter). Other brand, Fix a Loo or original Caroma washer (product code 405006).
6. I encounter a difficulty to put the plunger into the seating.Due to a very tight space for this Uniset model, it is quite difficult to do it (30 years old plastic may break), hence, it is a bit worry to do it. Following the reverse order of dismantling, it should be easy to align plunger three holes at the outer diameter of the plunger, so the three catches/lugs can be inserted into the bigger holes of the plunger. once the three lugs are inserted into the three holes, rotate clockwise to lock them into the smaller hole of the plunger.
What is the best ways to overcome this issue? Has any one encounter this problem?
I was thinking if I can rotate the Seating valve seat by 15 to 20 degrees (about 1/8 turn clockwise or anti clockwise, this will make inserting the three lugs/catches of outlet valves into the holes of plunger easier. This is due to poor design of Carome Uniset 1, dual flush cistern. or I have missed the proper installation process.
To rotate it, I need to use very large shifter or wrench to unlock the plastic locking nut on the outlet pipe, under cistern. (very tight space and not easy to work). Another option is to remove the cistern by removing the inlet valve water pipe connected to Cistern and two screws holding the cistern to the wall. Once the cistern is removed, I can work on the bench to rotate the seating valve seat.
Kind Regards,
Simon
