Hi everyone. Please excuse me as english is not my first language.
I want to know how to go about installing a retractable awning to the side of my house. House is timber frame brick veneer so i understand that the awning must be secured to the studs, not the brick veneer.
However, i have some questions:
- How can I determine where the studs are?
- Drilling into the studs means penetrating the moisture barrier. Will this cause water ingress and problems long term? If so, what can I do to avoid this?
- Awning brackets are wider than the stud thickness (90mmx120mm - see last photo - vs stud 35mm/45mm) plus the locations of the studs might not line up with the required locations of the awning brackets. So am i on the right track for thinking of fixing a ledger board (120x45) into the studs then the awning brackets onto the ledger board?
- Do i require a council permit for this?
- There are weep holes above the sliding door. I obviously don't want to cover them. Should I install the awning above or below the weep holes or it doesn't matter?
- What else do I have to consider?
Awning cassette length 3500mm. Awning protrusion 3000mm. Length of area in question 3740mm. Width of brick area in question 470mm.
Thank you in advance.
