Have a handyman w cabinetry skills. He said he could remove and replace w new 'plain narrow edged white laminex surround...but, l'm concerned, it might be whiter being new. Any suggestions?
Hello @M3gz
Thank you for sharing your question about your shadow box door. It would be fair to say that it's possible that new door will stand out just a bit as it is brand new. It does not have any scratches or wear and tear marks on it. It's not covered in a light coat of cooking smoke, and because its brand new it's paint is in full bright mode as it has not been exposed to UV.
Getting a close finish is definitely possible, getting a perfect match will be highly unlikely. My advice is to be ready for that possibility. But as the paint surface ages and settles in, it will eventually stop standing out as a brand-new door. I suggest taking one of your doors to the paint specialist at the store and asking for a colour match. They will then mix you up a batch and you can use that to paint your new door.
One other material that came to mind is to use a https://www.bunnings.com.au/custompine-carcass-ds-16mm-2400-x-1200mm-mr-particleboard-white-matt_p0097412 . These panels are covered in a default white melamine sheet, but I would strongly advise bringing a door sample so that you can compare it to the finish of your door.
