wanting to use Tuffblock but unsure if it would raise the deck higher than the current patio.
Hi @Devwah,
That's certainly something we could help you with if you could give us an idea of how high the current patio is relative to the ground the tuffblocks would sit on. A couple of photos of the space, as well as some measurements would certainly help with this.
To give you an idea, if you were to use the https://www.bunnings.com.au/tuffblock-300-x-300-x-90mm-instant-foundation-system-deck-support_p2410345 with 90x45 framing and 19mm decking boards, the total height above the ground surface would be 159mm comprised of 50mm from the Tuffblock, 90mm from the framing timber and 19mm from the decking board.
Given that most timber suppliers wouldn't recommend using timber smaller than this in a decking application, this is the lowest you can go using tuffblocks.
There are lower profile pedestal feet available if this does not meet your requirements. You could also look at excavating the area slightly if this is an option as well.
Let me know what you think. We can certainly assist further if required.
