Looking to remove stick on tiles and place new ones on and seal. I think i have the appropriate things. Just wanting to know the best way to clean up the sealant so it's neat and doesn't go everywhere.
Hi @JaneWT9295,
Luckily, we have a guide that will take you through things. Check out https://www.bunnings.com.au/diy-advice/home-improvement/baths-showers-toilets/how-to-apply-bathroom-sealant for some guidance on the process as well as recommended materials and tools.
To seal around the edges of your stick-on tiles, I'd recommend using a bathroom-grade silicone sealant such as Selleys Wet Area Silicone.
Start by ensuring the tiles are firmly attached and the area is clean and completely dry. Apply masking tape along either side of the joint to keep the silicone lines neat.
Cut the nozzle of the silicone cartridge at a 45-degree angle, then use a caulking gun to apply a continuous bead of silicone along the joint.
Spray the silicone with some water mixed with dishwashing liquid, then smooth the bead using a silicone finishing tool like these https://www.bunnings.com.au/paint-partner-4-piece-silicone-scraper-set_p1660196 . Then, carefully remove the masking tape before the silicone begins to skin over. Allow it to cure fully according to the manufacturer's instructions before exposing it to moisture.
