Hi, i have a retaining wall, thats more of a plantar box, that i need to build in front of my deck. Its 600mm high by about 5.4m long, and will be 1m wide. I would like to cover the treated pine sleepers with spotted gum decking, and wondering if this is ok to just screw the decking boards onto the uprights? Was going to use 200 x 75mm TP sleepers as uprights.
Secondly, is it also possible to use stacked stone veneer on a TP sleeper wall? If i put up some thick cement sheet between the uprights, will it be ok to glue the stacked stone to this, or is a TP sleeper wall to unreliable to to this method?
The sleepers would be on one side of the uprights, and the sheeting on the otherside, so not directly touching.
Hope that makes sense!
