Hi all, total novice here! I have had some trouble turning our cold water tap on in our ensuite vanity. It's hard to turn on, doesn't turn far, and when it does the water only trickles out.
I replaced the washer even though it is only around 4 months old as when I took a look the existing one (rubber/plastic combo) seemed a bit caved in at the bulbous end. This however has not rectified the issue.
I am in a rental so before I jump through the hoops of logging a maintenance call and having to double handle things between the Real Estate and Landlord, are there any other quick fixes I could try to see if I can resolve the issue myself?
Cheers!
Edited to add photo
