Which size waste stack pipe is required to service both the kitchen sink, dishwasher,laundry sink and washing machine ?
At the moment it has a 50mm galvanized steel pipe which seems to struggle with the load. It is rusting and needs replacing.
Should I naturally replace with a dwv pvc 50mm pipe or upgrade to 65mm to improve water flow ? Naturally will need to use a reducer at the junction (65mm to 50mm ).
