When using versilux product to line a shed timber stud wall , do you also need to also use adhesive glue prior to nailing???
Welcome to the Bunnings Workshop community @prawlo. It's great to have you join us and many thanks for your question.
I've made contact with the manufacturer James Hardie to double-check on the installation process. When installing Versilux sheets internally (not exposed to weather), onto timber studs, only the joining strip and nails are to be used. No adhesive is required and is not recommended.
Below is a diagram which I trust you'll find useful on how the Versilux should be installed.
