I'm trying to plan to build a low level deck and need some help. The clearance off the ground would be about 250mm and for this reason I was thinking of just running Joists from the back of the house. I'm wondering if I use H3 treated pine 190mm * 45mm joists and fix directly into concrete flooting
with stirrups or existing slab with Dyno bolts. Would this be sufficient enough? If this will be okay, how far apart should I drop footings? Every 1.8m? I will be running the joists every 450mm and using the joist hangers.
