I am assembling a PRACTA 1000mm base cabinet, the sections of which are joined together by cams and pins. I have connected all panels except the last side panel which has 14 pins. The pins line up with the holes but won't go in far enough to lock with the cams. Any help would be appreciated. As a last resort I might remove the pins and screw the panel to the rest of the cabinet. Thanks
