I am going to install a tv wall mount to a hebel wall, what is the best way of securing the wall mount bracket to the hebel wall? It is not a very big tv so under 10 kg in weight.
Thanks for any help.
Welcome to the Bunnings Workshop community @trevorwimmer. It's great to have you join us and many thanks for your question.
The recommended way to secure to aerated concrete is with Ramplugs. The Ramset 10 x 80mm Ultra-Long Hex Anchor RamPug - 10 Pack would be an example of a suitable product for fixing your mount. You will need to check what size holes are pre-drilled in your mounting bracket and get the correct sized product to suit. Ramplugs are also sold without screws if you require a different size to suit your mount.
You do not want to over-tighten the fixings and they only require you to nip the screws up firmly.
Please let me know if you need further assistance or had questions.
Do these ram plug fixings need any glue or adhesive to hold them in the wall?
kind regards
Hi @trevorwimmer,
No, they don't need adhesive to hold them in the wall.
Thank you so much for your help
