Hi. I installed a 250m if 19mm poly to transfer water however the sun has flattened the pipe due to heat build up. This is not green or blue line pipe but the cheapest from Bunnings. Is this faulty pipe or incorrect application? If the latter is true, which one should I use? I don’t have the opportunity to bury the pipe due to hilly and rocky terrain
