Hey All,
We are planning to build a freestanding pergola 2.2 m X 2.7 m. We got timber delivered from Bunnings about a month ago. I am in process of preparing things to get rolling.
1. We had concrete apron poured around our house and we had to extend this concrete slab in order to mount pergola posts on it.
2. We are thinking to use Chemset 501 to secure the anchor and then put bolt down stirrups. (I had to read multiple articles online to decide on whether Chemset or Dynabolts). I had to make a call based on what I read. Please feel free to add your inputs and share your experiences in this regards.
3. I had to level the previously poured concrete slab so that when I install bolt down stirrup it does not go inclined (as concrete is poured to make water run away from building). We used Dunlop construction grout about 20mm to make it a flat and level surface for stirrup.
4. Now looks like I have hit another hurdle. We have Cypress posts of 125 X 125 and 2.7m in length. Beam of TP 240mmX45mm (2.2m length post to post). I am planning to use 3 Bolts M10 X 150mm or +220mm Cup bolts (based on notch it or not) to secure beams to post.
5. We have Rafters 140X45 and Louvers 90 X 45 to be sitting on beams.
What are you recommendations on securing / mounting beams to the posts? Is notching good or it weakens the posts?
Kindly share your experiences and inputs.
Thanks in advance.
Stallone
Side view.
When you look straight at the post
Topview before notching
