Hi all,
My first post disappeared so I'm trying again with my two questions!
I'm building a covered alfresco area of 6m x 4m supported by timber stumps. Most are 100x100 but there are three 150x150 to support the roof load.
I've attached the subfloor layout to help visualise my questions!
1. The line of posts along the left side of the drawing sit about 500mm off the brickwork of the house so notching the double bearer into the posts could be difficult. Am I best to sit the bearers on top of the posts? If so what connectors should I use? Tie down strap and skew nails? Or could I use something like a triple grip?
2. I'm having trouble working out how the bearer and joist interact with the corner 150x150 posts (P1). I will notch out the front of the post to house the bearer, but then do I notch the side of the post directly above the front notch so that the joist can sit level on top of the bearer but somewhat inside the post? Feels like I'm cutting out a lot of that post given it is contiguous and runs up to support the roof load?
I am in Victoria if that makes any difference to codes or standards!
Help!
