Hi all, looking for advice for using a Venturi system for fertilising/seasol my garden using the watering system. What strength solutions should I use?
Hi @Grub80,
What type of venturi system are you planning on using? All the venturi systems I have seen have had an adjustment that allows you to set the rate the solution is mixed with water. They use a concentrate solution and the dial is set at the rate the producer suggests their product should be disperssed.
