Great community here. I've been reading a lot about building a low level deck. But still have a few specific questions just to make sure before I buy the materials.
I plan to build a low level decking on top of my concrete floor and will span around 1.8m across the grassy part to the right of the photo.
I plan to use 70x35mm for the joist as it has enough height to just level with the floor of the house after decking is installed.
Questions:
1. for the 1.8m joist that will span the right side, do I need to double up the 70x35mm joist? or single is ok?
2. for the bearer, I'm planning to use 140 x 45 mm how far from the concrete floor can I position it? Can I have just one bearer positioned 1.8m from the concrete floor? or do I need to put 2 bearers 0.9m apart?
3. Joist spacing should be 450mm? is this the same if I will use pine?
Thank you!
Community manager's note: Check out How to build a low-level deck for expert advice.
